Leaking Water Jacket Cover on 1934 Hudson
I posted about my water jacket a little while ago.
I managed to patch up the rust holes in the cover with JB Weld and am waiting for the ROC to get a new batch of stainless steel covers made up.
I re-installed it using a home-made cork gasket sealed with with a smear of silicone and that has proved completely watertight.
I used new stainless steel screws to attach it, smearing the threads with Wellseal, but I've got a number of slight water leaks around some of the screw heads.
These disappear when the engine is running - due to heat expansion I suppose - but reappear after everything cools down.
Has anyone experienced the same problem with water jacket screws ?
I might try but some extra Wellseal on the threads but would wrapping the threads in PTFE tape or smearing them with silicone sealer be a better solution ?
I'd appreciate people's thoughts, please, before attempting a remedy.
RIGHT BOLL
My water jacket restores
I wish I could change the title of the post.
https://forum-hetclub-org.translate.goog/discussion/365896/intake-valve-hudson-8-1934?_x_tr_sl=en&_x_tr_tl=fr&_x_tr_hl=fr
I'll try to get some CRC as Geoff suggests.
I've used red fibre washers underneath steel washers with the bolts (that's what were there when I got the car and it ties in with the ROC procedure manual).
Should I substitute soft copper washers ?
Copper washers it is !
Thanks to Toddh for the torque settings; I've been afraid to tighten the bolts to much because of the fibre washers breaking up.
Should I still put steel washers on top of the copper ones ?
I put two nuts on the bolt, grind the exposed threads off and removeing the nuts cleans up the threads for easy installation. This closely approximates the thickness of the block at threaded area.
Right now I am repairing the water jacket mounting holes in another Essex block, 1929. The origional bolts protude into coolant and rust. Of the 16 bolts 8 broke off. No amount of penetrating solutions will soak in to reduce the swelling of the threads in the coolant cavity.
Note. Bolt retention is not determined buy the amount of thread protruding into the coolant. Rule is, the effective penitration length of the bolt is equal to diameter of bolt threads.
I'll just use copper washers (I think brass washers won't squash down as much copper washers) and I'll try Loctite Blue on the bolt threads rather than Wellseal.
Loctite Blue has provided a totally leak-proof seal on my water temperature sensor fitting's threads and should do the same on the water jacket.
Order today received tomorrow
