6 volts do it again
I went to check my '36 Terraplane yesterday. It has been parked in a garage across town over the winter up to now, with the battery left connected and not trickle-charged. I already knew that I had left the car before for 19 months and it started fine, so I was interested to see what would happen this time, after about 7 months.
The battery is 600CCA and 2 years old.
I put a tablespoon of petrol down the carb, turned on the ignition and pressed the starter. It fired right up then died again as the fuel pump had not quite pumped enough fuel through. A few more seconds on the starter and it was away as if it had been parked overnight! I took it for a drive around the local area being a bit careful as it is not licensed currently. I brought the battery back home and put it on the charger which showed it wasn't even that discharged, and reached full charge again after a few hours.
1933 Essex Terraplane Eight
1936 Terraplane
1936 Hudson Eight
A friend with a '37 Terraplane bought one of those covers that look like a traditional battery because his Optima is in the engine compartment - it looks good.
51 Hornet Sedan
51 Commodore Six Club Coupe
50 Pacemaker Deluxe R.I.P. (burned and destroyed in building fire)
49 Super Six Sedan
hi - i have classic cars using both 6V and 12V optima batteries and trickle chargers - about 20 years ago, when i purchased trickle chargers, there was a difference noted for conventional vs sealed batteries and i made sure to purchase the correct charger (one would overcharge the other)
- years later, i needed more chargers and i no longer saw this distinction - i checked with one of the manufacturers who told me that with the newer computer tech in the trickle charger, it figures out whether the battery is conventional or sealed, so just make sure it's for either 6V or 12V - (the new trickle chargers even have ext thermometers to adjust for outside temps)
- i've used trickle chargers throughout, no problems, only successful starts!
hope this helps
