50 super high beam difficulty
My 50 super lights won’t work with high beams on for mor than a few seconds. They’ll come on then my breaker trips and I loose everything . Went through the dimmer switch and reassembled it with dielectric grease , it helped but no cigar.
Headlight grounds maybe?
Any help appreciated!
-Blake
-Blake
@Lance & @Geoff im wondering but most of that has been chased, must be a more recent one. I have bad luck with headlight harnesses in Hudson’s 🤦🏼♂️
@Toddh thats news , always been told it’s a conducting protector.
MG Chemicals - 846-80G Carbon Conductive Grease, 80g Tube https://a.co/d/0hfcA04
the switch is already back together and afraid that If I where to take it part again I’d break it , pot metal housing . Chasing wires I guess is my next adventure, if it came to it what does a new headlight harness run? Anyone know? (Fabric covered of course)
You will need to rewire your lights. Yup, every wire (from the firewall at least) to EACH BULB needs to be cut and spliced and rewraped into a harness. And EACH ground needs to be cleaned to bare metal and reattached.
PITA yes, but there is no way around it. The circuits are simple and the wiring diagrams are clear and easy.
I just did in on my 42. Two days of messing around. I would replace one wire (stupid me just one wire) then hit the switch and POOF pop another fuse!!!
OK, I'll just replace the fuse and everything will be fine(?) Nope! pop another fuse.
18 blown fuses until I FINALLY had replaced all the headlight wires under the hood and to the dimmer switch.
I am just happy that the trouble started in my garage when I was fixing other things and NOT on the road somewhere. Old cloth wires are a huge fire hazard.
In the end ALL the lights are now as bright and reliable as any 12 volt bulbs.
The really black one is (was?) a 30 amp fuse and it exploded when I thought I was done. Nope the hood lights suddenly developed a dead short to ground. I was testing it with an awl (temporary connection) and the awl began glowing red!!!
Be Careful replace your wires.
http://www.riwire.com/
You could get one of those temperature guns and check the wires to see witch one is getting hot and go from their my 2 cents
Brillman (probably others too) lets you purchase cloth covered wire by the foot. The wires for the headlights and marker/running/turn-signal lights were originally in rubber tubing. Rhode Island Wiring sells the correct tubing by the foot.
@D7fever I’ll have to chase that wire and see , never occurred to me . It’s still nice and bright
@railknight I don’t make many swapmeets maybe 2 a year. But that’s a good idea!
