Timing Advice Requested
Old Fogey UK
I have a '34 Hudson 8 with a 254 motor.
The car only gets used on short runs because I live on the Isle of Wight (for those unfamiliar with British geography, this is a small island just off the south coast of England).
In consequence, I've had a problem with plugs sooting-up very quickly.
In an effort to prevent this, I've swapped to a hotter plug (Champion RJ12C) and only use 5% Ethanol fuel because British 10% is awful.
However, I'm getting an annoying exhaust backfire on the over-run after releasing the accelerator pedal and the plugs are still getting rather sooty.
This suggests to me that the ignition timing could need changing (presently TDC).
Please may I have some suggestions as to what might be a better timing point for my set-up ?
The manual says 4.5 deg BTDC. I would use that as a starting point for experiment and try the car on your favourite test hill. If it pings reduce the 4.5 deg, if it doesn’t ping run the car like that for a while and see how your plugs look.0
Any ethanol is too much! I doubt that ignition timing will fix this. Bob, have you ever been to the Isle of Wight? There are no hills. Exhaust "popping" on over-run is usually caused by too lean an idle mixture, but it could be the fuel itself causing the problem. when the mixture is too lean it doesn't burn in the combustion chamber properly, and accumulates in the exhaust system and intermittently explodes out the exhaust pipe. Is the automatic choke adjusted properly, and the pipe from around the manifold clear? What about the by-pass around the intake? If this is stuck in the summer position then the intake will not be getting enough heat around it to vapourise the fuel when cold running. You need to go to the mainland and give it a good run along the M1 perhaps!0
Thank you both.
My car is an LTS and so has a manual choke, which is set properly for my Daytona Universal carb (Zenith 228 lookalike with an adjustable main jet).
There is no bypass in the intake manifold; it's an ROC re-cast that just has an empty space inside and has a detachable blanking plate on the top where, presumably, the by-pass control would go - do I need to do something about that ?
The ROC official guidance is to set the timing to the long arm of the H on the flywheel to cope with modern fuel - does that sound right to you ? I haven't done that yet as I wanted to check it out on this Forum first.
Geoff - please don't ever say to an Isle of Wight local (they're known as Caulkheads) that we don't have any hills - they're very proud of our 850 feet high "mountain" !0 -
Yes, that is the correct timing light setting, at idle. The "new" manifold could be part of the problem, therefore not easily overcome. I understand that the main keep-fit exercise on I.o.W. is running up and down the hill every time the tide comes in!0
Re the ROC manifold etc. I removed the stuck temperature control from my stock 35 H8 manifold and blanked off the holes etc, which I guess makes it now little different to the ROC manifold.I also remade the gasket between the exhaust and inlet manifolds eliminating the exhaust gas circulation holes.0
Depending on how much gas you use, you could separate the ethanol from the gas using water, agitating then extracting the water layer.0
I have been burning ethanol gas in my 212 straight 6 for 20 years. The only issue I have ever had is a gas line that got soft and ballooned up.
Regards, Tom0 -
The summer winter position is automatic or changed manually? Here before editing on my survivor 34.Je would not want to be wrong at the reassembly. Thank you.
The original little box for the climatic is still present. It is on the side of the collector.
That’s not the climatic control box. That’s the place where it is supposed to be mounted0
Heres the box. Your car is supposed to have a Carter 282s carburetor
Yes I knew; it is indeed an original 282S. There is still the brass label that says 282S; the box is on the side of the collector not above. Here in the picture when I bought it. But I spoke instead of the summer-winter position. Is it done automatically or do you have to move a few things? Can anyone explain? Thank you
There was a happy ending on the timing issue.
It had been set at TDC by a local "expert" classic car shop.
It's now set for the long arm of the H at idle and the popping has gone.
The plugs are still sooty and I'm going to try a blanked off gasket as Bob suggests and I'll drop the float in the carb by 1/8 inch to see if that helps.0
- 102 Hudson 1916 - 1929
- 17 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 556 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 75 Hudson 8
- 43 FORUM - Instructions and Tips on using the forum
- 597 Vehicles
