Discussions
Official HET Club Web Site
HET Club Facebook Page
HET Historical Society
Home
HUDSON
Sign In
Register
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Sign In
Register
Quick Links
Recent Discussions
35.9K
All Categories
61
Hudson 1916 - 1929
13
Upcoming Events
59
Essex Super 6
27.9K
HUDSON
421
"How To" - Skills, mechanical and other wise
984
Street Rods
150
American Motors
156
The Flathead Forum
46
Manuals, etc,.
55
Hudson 8
36
FORUM - Instructions and Tips on using the forum
2.6K
CLASSIFIEDS
564
Vehicles
1.9K
Parts & Pieces
73
Literature & Memorabilia
2
Hudson 1916 - 1929 Yahoo Groups Archived Files
2
Hudson 1916 - 1929 Yahoo Groups Archived Photos
In this Discussion
August 2022
railknight
August 2022
Geoff
August 2022
JFromm
August 2022
54coupe
August 2022
Toddh
August 2022
cheyenne7271
August 2022
blondwookie
Torque sequence
JFromm
341
August 2022
in
HUDSON
Can someone post a picture that shows the torque sequence for a Hornet 308? Also need the foot pounds number.
Thanks
blondwookie
302
August 2022
I'd suggest that you start out in the center of the head and out in a circle. Something similar to torquing a 5.9or 6.7 Cummins diesel head
blondwookie
302
August 2022
They are both a 6 cylinder head in the bolt pattern
cheyenne7271
492
August 2022
Any head or manifold yiu always start in the middle and work your way out. 65-70 Ft/lbs for a Hudson cyl head.
51 Hornet Club Coupe
51 Hornet Sedan
51 Commodore Six Club Coupe
50 Pacemaker Deluxe R.I.P. (burned and destroyed in building fire)
49 Super Six Sedan
Toddh
338
August 2022
From the 1952 Mechanical Procedure Manual
JFromm
341
August 2022
Thanks for the help
54coupe
1,029
August 2022
I use this sequence for a Hornet:
21 15 9 2 6 12 18
17 11 5 1 4 10 16
19 13 7 3 8 14 20
Geoff
4,606
August 2022
Like 54coupe says. Use for all sixes from 1924 thru 1956 (except F-heads).
JFromm
341
August 2022
Geoff,
Are those numbers based on the factory picture or the numbers you gave in a post in 2007? You gave numbers on right side, left side, and middle.
Also is that right side as you look at it from front of car?
John
Geoff
4,606
August 2022
the front is to the left, but it doesn't matter as it is from the center out. That is the same as my sequence published some time ago.
railknight
521
August 2022
I believe Walt Mordenti pretty much recommended the same head bolt; torque sequence as suggested by 54coupe here.
Sign In
or
Register
to comment.
Forum Software Powered by Vanilla
51 Hornet Sedan
49 Super Six Sedan
21 15 9 2 6 12 18
17 11 5 1 4 10 16
19 13 7 3 8 14 20
John
