Anyone know offhand the diameter of a stock Hornet 308 cooling fan?
mine met a violent death years ago, I have installed a 18” 6 blade fan, but it’s pretty close to the upper rad hose. I am looking at installing a radiator shroud to help cooling
Dave Eddie
I am looking at installing a shroud onto the radiator,
the 6 blade fan I am using is 18” diameter and it does pass above the core, coming, as mentioned about 3/4” from the upper rad hose.
This makes fitting a shroud a bit of a challenge, but I’m sure it is do able.
Dave.
