Transmission fluid
New owner of a Hudson Hornet -52 and having some "newbeginner questions"..
How do I check the level of transmission fluid in my Hydramatic? And what oil should I use?
And what the adjustments of the kick-down link?
Thank you.
Thank you.
I was a beginner a couple of years ago on a 52 Hornet...and still somewhat the case. Anyhow, the transmission dip stick is accessed from the passenger side. It's on the transmission hump requiring carpet to be pulled back from firewall. I believe it's Dexron III or older conventional transmission oil/fluid. O'Reillys had a product that I used. The kick-down for me was trial and error getting shifts in the right place. Very, very small adjustments are probably advisable as its pretty sensitive.0
MikeD said:I was a beginner a couple of years ago on a 52 Hornet...and still somewhat the case. Anyhow, the transmission dip stick is accessed from the passenger side. It's on the transmission hump requiring carpet to be pulled back from firewall. I believe it's Dexron III or older conventional transmission oil/fluid. O'Reillys had a product that I used. The kick-down for me was trial and error getting shifts in the right place. Very, very small adjustments are probably advisable as its pretty sensitive.
I will have to look at the kick-down now the gears shifts to fast almost at the same time..
You are in luck.... our friend and now deceased HET GURU Alex Burr left a legacy for all the new and old HETers... a major treasure trove of scanned and PDF assembled and posted manuals that cover our HET CARS. You will find a very detailed manual on the transmission at this URL... http://hudsonterraplane.com/tech/1952/1952-53_Hydra-Matic_Manual-Supplement.pdf
You can download it to your smart device and carry it around with you or print it if that is a desire... you will find that http://hudsonterraplane.com/ will provide you with a bunch more manuals/
The shifting adjustment is detailed in the manual. If you do not have the special tool that is identified... you can use my website https://hudsonrestoration1948-54.com/
where you will find a method of adjusting the shifting points for your type of transmission.
Good Luck
Ken Cates0 -
Glowplug said:You are in luck.... our friend and now deceased HET GURU Alex Burr left a legacy for all the new and old HETers... a major treasure trove of scanned and PDF assembled and posted manuals that cover our HET CARS. You will find a very detailed manual on the transmission at this URL... http://hudsonterraplane.com/tech/1952/1952-53_Hydra-Matic_Manual-Supplement.pdf
Good Luck
Ken Cates
I hope I will get the shifting to work now at least I will know how to do it!
