Headlight issues...still, advice please
Hello all, so here is what I have, I put a headlight relay in my 39 six. I have no lights. So, I started tracing voltage. I have 6volts at the battery, to the starter 6 volts to the voltage regulator position B (which is what powers my fuse block. at position B on the fuse block where wire from regulator comes in, I have 6 volts. The wire that goes out to head light switch, which is SW position on the fuse block, I have 6 volts going to headlight switch. At head light switch I have 6 volts coming in. I have 5 volts coming out, 5 volts going into the dimmer switch. 5 volts coming out. 5 volts at the switch side of teh relay. O volts on the light side of the relay. Hence no lights. Not sure what to do next. I guess maybe remove relay and clean mounting surface of all paint. Could it be that the relay isn't getting a good ground? Please advise
