shifting into overdrive
so I have found and read all manuals and operating info I could find on line regarding overdrive units.
but I am very still confused how one actually operates this.
the only info that I can find that is clear, says one must pull out the over drive knob to put car in reverse.
but as far as forward motion it speaks of various mph, speeds, throttle pedal movement, a foot switch? but never refers to the actual proper movement of the over drive knob.
Does one pull it out before starting the car and shift the 3 gears normally, or does one pull out on the knob once a certain speed is reach? additional I have no foot switch, other then high beams.
car is a 51, 262 with a 3 on the tree trans and a overdrive unit with a manual pull knob on the lower left dash corner.
what is the proper way to operate this. any info appreciated.
You can start your Hudson with the overdrive engaged (knob pushed in) or disengaged. Sometimes when attempting to back up while in overdrive the car may not respond. Simply pull out the overdrive knob into regular drive and this should make it possible to back up. It's best to put the car in overdrive while the car is standing still with the engine running or not.
One of the nice things about overdrive is that after placing the car in 1st gear with the clutch, you should be able to shift up to 2nd, 3rd and overdrive without using the clutch as you accelerate (just let up on the gas pedal as you shift upward and then accelerate). Overdrive (4th gear) is reach after accelerating in 3rd gear and then letting up on the gas. You'll then feel and hear a slight thump as the car's transmission automatically shifts into actual overdrive.
When in overdrive you should be able to automatically shift down to 3rd gear by depressing the accelerator pedal to the floor which activates the "kickdown" switch underneath the pedal. This gives you quick access to a passing gear should you need it.
I'm probably leaving out a few things that others may expand upon, but this should give you a good start using overdrive. "Happy Motoring!"
all the info I found made it sound so complicated.
thanks!
They all shifted into reverse when the overdrive lever was pushed in.
There is a switch on the shift rail to lock out the solenoid.
51 Hornet Sedan
51 Commodore Six Club Coupe
50 Pacemaker Deluxe R.I.P. (burned and destroyed in building fire)
49 Super Six Sedan
51 Hornet Sedan
49 Super Six Sedan
