Head light hell
Ok here is what I got and think I understand. I'm no electrician by a long shot but I got a known good headlight relay. Installed and wired. No lights. I checked for 6 volts ( power) coming into relay. I have that. What I don't have is 6 volts at the switch side or lights side of the relay. So I checked ground. I took a jumper wire from ground at battery and clipped to base of relay. No dice. But when I manually operate the relay by tapping the coils on it the lights do come on. So long as I hold the contact down. So I seem to be not getting voltage from the light switch or maybe dimmer switch? Please advise as I'm about to pull the rest of my hair out!!!
Were you fortunate enough to get the relay wiring diagram?
The relay unit needs to be "told" (by the dimmer switch) whether the high or low beam should be on. Does one wire run from one of the dimmer switch output terminals to the "high beam" terminal on the relay unit? And does another wire run from the other dimmer switch output terminal, to the "low beam" terminal on the relay unit?
And is the whole relay unit properly grounded to the car, so there is a complete circuit from dimmer switch to the corresponding terminals on the relay unit?
Now, moving along to the actual headlight circuits, you need a hot wire on the voltage regulator feeding the main power terminal on the relay unit. Tromping the foot switch directs this power from the hi beam relay to the high beam terminals of both headlights, or from the low beam relay to the low beam terminals of both headlights.
Of course, both headlight sockets will need to have a good ground. (I have soldered ground wires on my pre-war car's sockets, and screwed them to the car frame.) This completes the headlight circuits and should result in light!
The ground to the relay unit only completes the dimmer switch circuit. The headlights themselves will need their own grounds.
You've said that the lights only come on when you manually tap the coils. The dimmer switch should be activating those coils, not your fingers. Something is wrong with that dimmer circuit.
By the way, pease don't pull the rest of your hair out.
