Tapping for 1/2" head bolts
My head gasket went bad again. One of the bolts wouldn't achieve full torque. Now I know why... the 7/16 bolts threads pulled out on one hole. The diameter measures .428" (technically that's .020 oversize for the minor of a 1/2-13).
Should I tap this hole for 1/2-13 as is, or should I drill up and tap for Heli-Coil? That drill size is .531". Seems like a lot of material to lose, but I wanted to ask you guys.
Ivan L.
https://www.lawsonproducts.com/Supertanium/SS-Locking-Thread-Insert-716-14/P34302.lp
http://www.timesert.com
Here is a thread on stripped threads.
https://www.jalopyjournal.com/forum/threads/drill-tap-vs-helicoil.590154/
regards, Tom
51 Hornet Sedan
51 Commodore Six Club Coupe
50 Pacemaker Deluxe R.I.P. (burned and destroyed in building fire)
49 Super Six Sedan
Larger threads in the block and normal threads for head nuts.
could save the problems of several items of concern.
For the intake/exhaust gasket I used the Remflex Graphite gasket.
Very pleased with the results.
