Eliminating drum brakes and under floor mechanism in 51 hudson
in Street Rods
I want to know and see pictures of a setup with disc brakes and under floor brake components removed from Hudson and using a firewall master cylinder and hanging brake pedal like today's vehicles. That's of course if anyone has done this
There are many discussions on the rest of the disc brake conversion process on this forum.
Ive done it using a mid 2000 Chevy Malibu Swing pedal assy with Power Master Cyl by drilling 4 mount holes then Hole sawed center hole. I ran line from large chamber to front brakeS then small chamber to rear. No firewall flex...Midnite so will look for pic tomorrow.
I made my own disc brake Set-up too. I Cut the bracket from 3/8" plate, Chry Sebring Rotors, and GM Calipers. However, today I recommend contact Starbird for their Bracket then they give part numbers for all componets needed from local Auto Supply.
>>>> https://goo.gl/photos/QEtE7t64Ebs53teC8
No maint. required anyway other than a MC rebuild !
SO......................
