Strange noise
Voltage regulator good suspect. Overdrive relay possibly0
And that is the reason I disconnect the battery on All my vehicles especially my vintage cars when I leave them in my shop or in storage
I would hate to loose all my cars and tools to a available fire 🔥
just my 2 cents
John0 -
2x that. Years ago I thought they weren't all that necessary. Then, one cold January morning while I was hosing down the ashes of a guy's home and watching the carcass of his Covette steam, it hit me. A $12.00 switch would have meant this house would be more than a foundation and I'd be at the station drinking coffee. I bought a battery switch for my Bel Air that weekend....0
I would imagine a buzzing noise like that would be pretty easy to trace especially with an engine stethoscope.0
Thanks for the help. Will further investigate.0
John, do you have any idea from whence the noise was emanating? It could be the clock, if there is one fitted.0
ALSO DO AS I HAVE: BUY A SMOKE ALARM WITH A RELAY INSTALLED {THESE ARE GENERALLY HARDWIRED, 120V}, THEN RUN A PAIR OF WIRES (THRU TREES, ETC) TO AN ALARM IN YOUR BEDROOM. IF THE ALARM GOES OFF AT NIGHT, ETC. IT WILL OPERATE AN ALARM IN YOUR BEDROOM. YES, DOUBLE PEACE OF MIND !!!!! There are more fire sources than just a disconnected battery !!!0
RichardD said:ALSO DO AS I HAVE: BUY A SMOKE ALARM WITH A RELAY INSTALLED {THESE ARE GENERALLY HARDWIRED, 120V}, THEN RUN A PAIR OF WIRES (THRU TREES, ETC) TO AN ALARM IN YOUR BEDROOM. IF THE ALARM GOES OFF AT NIGHT, ETC. IT WILL OPERATE AN ALARM IN YOUR BEDROOM. YES, DOUBLE PEACE OF MIND !!!!! There are more fire sources than just a disconnected battery !!!0
