Wiring harness
53jetzabu53jetzabu Posts: 24Member
Where does the wiring harness run from front to back?  under the carpet?  I have a problem with the driver side courtesy light, on my 1954 Coupe. How do you access this light, to check for an insulation problem, removing the lens is no help.  Thanks
  • cchancelcchancel Posts: 184Member
    I believe it runs under the headliner.
  • charles4dcharles4d Posts: 625Expert Adviser
    Over the  drivers side door under the headline I think
  • 29sptphaeton29sptphaeton Posts: 373Member
    On my 51 it ran under the plate. I had to remove the sill plate and then another plate under it.
  • blondwookieblondwookie Posts: 239Member
    On my car, all of the center wiring and rear wiring was in the edge of the headliner on the driver side of the car. My car is a coupe too
