35 terraplane center hood brackets
Please create new discussions if you are seeking parts rather than adding to an existing one
This discussion was created from comments split from: Center Hood Brackets.
Would these be the same for a 35 terraplane, I need a set?
JML55 said:Would these be the same for a 35 terraplane, I need a set?0
Old Fogey UK said:JML55 said:Would these be the same for a 35 terraplane, I need a set?0
Toddh said:Old Fogey UK said:JML55 said:Would these be the same for a 35 terraplane, I need a set?0
Todd - your rear bracket is different from mine. Is it original? Both of mine look like your front one.0
Yes it’s original except for the screws.0
Toddh said:Yes it’s original except for the screws.
If your set up is the same as mine with identical brackets at each end, JLM55 ought to be able to use the end clamps from Vintage Car Parts because the chrome hinge strip they sell in conjunction with them has the same profile as the original Hudson hinge strip.0
