Does this hub puller fit Hudson or Essex?
lostmindlostmind Posts: 1,587Expert Adviser
2 1/4" x 14 tpi
Estate sale people said they were told Hudson/Essex , but I have no source to find out.
$50 plus shipping if someone needs it.
Thanks
Wellington , Ohio
  • HansHans Posts: 279Senior Contributor
     Can you provide ID  ( internal diameter )and TPI threads per inch.
    Using your ruler, looks like a little over 2 1/2  inch id.
    But not good enough.
    thanks, Hans
  • lostmindlostmind Posts: 1,587Expert Adviser
    thanks, Hans
    I Did , it's the first line.
    2 1/4' inside , 14 threads per inch
    Thanks
    Wellington , Ohio
    Thanks, Roy.   I missed it by just reading the words.
    1927 to 29 Essex uses 2 1/2 ID  with 16 TPI
    1930and 31 Essex uses 2 3/8 ID  with 16 TP
    I do not have earlier or later hubs or hubcaps to check.
    Thanks , 14 is an odd tpi for a puller. A 16 gauge seems to fit , but the 14 is better.
    Wellington , Ohio
