Rotors
Trevor JTrevor J Posts: 461Expert Adviser
Can anyone on the forum give me the correct numbers for the Hudson 8 distributor rotors from 1934 to 1942.  I understand there were also aftermarket suppliers apart from Autolight.  Their numbers would also be helpful
  • bob wardbob ward Posts: 1,301Senior Contributor
    Not what you're asking but I've recently bought a 35 distributor kit from Wildrick, cap, rotor, points and condenser
  • eddiehudsoneddiehudson Posts: 45Member
    There are more than 20 different companies that sold rotors. Most were bought from the same supplier.
    Here's a few, 1930 - 47 HUDSON 8
    Autolite - IG 1576
    Echlin - AL 46
    Filco - AL 88
    G.P. - AL 45
    KEM -1542
    STANDARD - AL 69
  • Old Fogey UKOld Fogey UK Posts: 778Expert Adviser
    You're in NZ - If your car is one of the British assembled Hudson Eights, some of them used a taller distributor arm and cap than US cars. All such ones I've seen are marked
    "Made in England ".
    You can't use these arms in the shorter US caps. I don't know if you can use the shorter arm in the tall caps.
  • GeoffGeoff Posts: 4,316Senior Contributor
    British engineering philosophy: "If something works perfectly well, redesign it until it doesn't".
  • Trevor JTrevor J Posts: 461Expert Adviser
    Thanks for all your help.  I will stay away from the English ones
    There's one here if anyone ever wants it.
    There is a rotor listed for sale with an auto light part number IGP 1016B says it for Hudson 27 to 47 does anyone have a listing for that number
    IGP 1016B = 1948 - 52 8 cyl
    Thanks
