52 Hudson Hornet fuel tank filler trunk floor seal
pbhornetpbhornet Posts: 3Member
Hell does anyone make a seal for gas tank filler tube where it goes through trunk floor Thanks
  • GlowplugGlowplug Posts: 2,200Expert Adviser
    Your second picture shows the heads of three push through pins.  On the bottom of the floor where these pins protrude are clips that hold them in place.  Attached to these pins are three metal plates. These plates are meant to hold a piece of rubber cut to fit around the filler neck.  Remove the pins cut a piece of tire inner tube rubber to seal the opening, make holes in that rubber to accept the pins using the plates to hold the rubber in place.  In my rendition I used a tube of roofing asphalt to seal below and above.  My repair is water and dust proof after 25 years,   Good luck.
  • pbhornetpbhornet Posts: 3Member
    Thanks
  • BigSkyBigSky Posts: 942Senior Contributor
    Here are a couple pictures of my 54 Hornet.
    Undercarriage view:
    Trunk view
    Nice thanks
