308 thermostat housings
blondwookie
This is my head for my 308 engine. I have a thermostat housing that does not have the coolant bypass in it and I also have a housing that does have a coolant bypass in it. Does it make a difference in which housing that I use on my engine where it concerns cooling?
If you use the housing with the bypass and don't block off the bypass then you will have to use one of the old-style thermostats like the Hudson 166272 or you will have a significant quantity of coolant bypass the radiator. I haven't seen a housing that fits that doesn't have the bypass.There is a good discussion on the bypass and thermostats in the cooling section of this website: https://hudsonrestoration1948-54.com/
The housing without the bypass is 55-56. You can use it on previous years.0
If you use the 1955-56 housing, what modifications are necessary for using a modern thermostat such as the suggested M.G. #4366?0
Railking the only concern is the depth to allow the thermostat to fully open. May need as spacer like Walt used to sell?0
railknight said:If you use the 1955-56 housing, what modifications are necessary for using a modern thermostat such as the suggested M.G. #4366?0
I broke the bypass housing today while trying to get the thermostat out. What is the highest possible thermostat that I can use in a308 engine? I have read that only a160 degree thermostat is to be used. Can I use a 180 or 195 degrees thermostat? I will be using a new radiator when I rebuild my 48 club coupe
