Jet axles
JFrommJFromm Posts: 297Senior Contributor
Are the axles the same for the automatic and the manual shift? If not, how can you tell the difference?
  • LanceLance Posts: 952Member
    They are the same John. No difference.
  • GeoffGeoff Posts: 4,149Senior Contributor
    They are different ratios.   There should be a tag on a cover bolt with the ratio on it.  Auto was higher ratio than the manual
  • JFrommJFromm Posts: 297Senior Contributor
    Thanks for the help.
