Headers
We are kicking around the idea of producing a header to fit the 48-56 Hudson big sixes. We would like it to be able to be used on the pre-stepdown cars as well as the stepdowns, and be of a longer tube variety than what is currently available. A six into one design is not out of the question, and would make running a full length exhaust system easier. I would be interested in hearing opinions. At this time, we are not asking for commitments, just trying to gauge if there is enough interest to even keep talking about it.. We have seen headers that are currently available that have serious fitment issues in various areas, with questionable welding, and I have no doubt we can produce a better product. What do you think?
A number of years ago someone else was making headers and they seemed to be well regarded. I don't know any details on the design however.
TWIN-H-manifold include a picture fo all of us to see, I am interested in a set.
RUDY Bennett
Agreed! If I am using the stock exhaust manifolds, I usually open the outlet up to 2 1/4" just to try and get it to breathe a little better but would definitely be interested in a header like the one pictured above.
I have used this company for header coatings https://swaintech.com/race-coatings/race-coating-descriptions/white-lightning-exhaust-coatings/
Coatings: Are They Worth It?
As a part of our test, we wanted to quantify the benefits of a coated header versus a plain uncoated black painted header. A thermal barrier ceramic coating adds considerably to the price of any header, often doubling the price. We tested two otherwise identical Hooker 1⅞-inch headers with surprising results. Running on the dyno, we found the power numbers virtually unchanged (see Average Power table on next page). Where the ceramic coating made a remarkable difference is in the heat transferred by the header. We tested the header temperature immediately after a run, and then one minute after shutdown. The coated headers measured 258 degrees F dropping to 195 degrees F a minute after shutdown. In contrast, the uncoated header measured a scalding 870 degrees, retaining 520 degrees a minute after shutdown. We didn't need a heat gun to tell the difference in the test cell.
Our next test loaded the engine to 60 lb-ft of torque at 2,800 rpm, simulating a high-speed cruise situation. We gauged the surface temp of the header once fully stabilized. Once again, the difference was huge, with the coated header showing 288 degrees, while the uncoated header recorded 850 degrees. While the dyno run didn't show much difference in output, an engine breathing air from under the hood will definitely feel the effects of that extra 562 degrees F pumping into the engine bay. Taking account the effects of heat on engine component life and passenger comfort, the coated headers are definitely a winner.
Link to article:
Hoker Headers - Headers Dyno Test - Popular Hot Rodding Magazine Page 2
https://swaintech.com/race-coatings/automotive-coatings/automotive-coatings-price-sheet/
Jay
