1934 Hudson 8 cylinder clutch repair
I am in Australia and have a 1934 Hudson Coupe with a 3 speed and 8 cylinder engine
I drive the car most weeks and love the car
I have to do the clutch and would like to do the recorking my self I have lathes milling machine et so could make tools to compress the cork to get them in cut the cork to size etc
Is the cork any thing special I assume you cant use the rubberized cork used in gaskets and how far should the corks stick above the plate on the new clutch
The car has a baker front end I remade all the steel bushes and 2 solid steel spring hangers this took nearly 2 weeks of machining So I am capable of making things for the car just need some specs and pointing in the right direction
Many (most?) of the Hudson clutches that get refaced in Australia get done with kevlar, I had my first one done 25 years ago. Les P was the pioneer down here of kevlar Hudson clutches.
It twists the front springs and is only good for about 15 to 20 thousand miles before it needed bushes and pins its all steel to steel
Now the roads are much smoother and I also grease it every 500 to 800 miles and modern grease is much better as well so I will see how it goes
I would rather use cork for the clutch it did work fine I would like to know what thickness to use and what type of cork to get I can make tooling to cut the cork and will make a little press jig to install it through a tapered sleeve and can machine the cork in a lathe once installed to make it all true and aligned just need to know the dimensions used if this is not available well a good old guess with do
I am not up to speed on that but think that some wine bottle cork is synthetic I believe I am not sure but would think it may be ok to use I think gasket cork that is rubberized would not be good unfortunately I have a few sheets of that LOL
Hudson would have used raw cork for sure
my father would compress the plate in a jig for a few days and then machine them off in a lathe to size, very dusty and dirty job.lol Thickness is indeed .210"
I would hate to think how many clutch plates we did over the years working in our workshop. I always advise soaking the finished plate in a dish of ATF Fluid before installing, saving to top up after the corks have absorbed fluid after installation.
By the way is it a 9" or 10" plate.??
https://www.bcafrictionmaterials.com.au/products/woven-roll/
BCA have done a number of 9 & 10 inch clutch plates for Hudson & Terraplane vehicles.
No matter whether you go for corks or kevlar, make sure that your clutch plate has no movement in it.
Is your Hudson green and did you purchase it from the late Clem Smith's auction?
I am not sure if you are aware, but there are three excellent HET Clubs in Aust - Vic, NSW & Qld and there is a lot of Hudson knowledge within the membership.
I am impressed just how well the 1934 drives I just love it and drive it almost every week
Are the kevlar linings glued on or cut and pressed into cork holes
I really am a easy driver on the cars and think corks would see me out I have also found on both cars I when finished driving them for the day I bring the revs to about 1000 rpm with my foot on the clutch turn the motor off and hold the clutch down for about another minute this lets the oil run down over the corks between the flywheel and pressure plate and is reduces the sticking quite a bit if I have not driven the car for say a few months I may start the engine push the clutch in while it warms up a minute or so just turn it of then start it in gear and it is always fine after that
I am down on the Mornington peninsula and will make a tapered fitting tool and will machine the finish plate in a lathe I still have not pulled the clutch out as yet its a job for tomorrow so don't know if it is 9 or 10 inch I am not 100% what went wrong it was strange a while ago I think the clutch slipped but on over run coasting down hill just once or twice but on driving was fine and yesterday just going up a slight hill in top just bang and no drive so it may even be a broken spline or drive plate it still rotated the gear box but not enough to drive
Consider the humble wet clutch forklift, there are hundreds of thousands of them all around the world being worked hard (flogged to death?) day in day out, they all have kevlar clutch facings.
This is why I prefer a kevlar clutch in a Hudson.
I don't mean to be scornful or disrespectful of those who prefer a cork clutch.
The diff has loosened the 6 crown wheel bolts then sheered them off unfortunately it took 2 teeth of the pinion gear funny thing it did not make and noise it was quiet and smooth
Does any one have a crown wheel and pinion or a diff center for sale for a 1934 I do have a crown wheel and pinion for 8 bolt Hudson i assume the next model but it is very different and would not fit
Where can I find out more about them, please ?
Apparently there is no method of distinguishing between the 6 bolt and 8 bolt centres while they are in the housing, you have to dismantle the diff to find out what you have. The advice about the man in Adelaide is sound.
