Time to Remove the Cylinder Head ?
I am trying to resolve problem of the spark plugs sooting up on my 1934 254 engine.
Advice from Geoff and the ROC was to try hotter plugs so I replaced the 3/8" B6S NGK plugs with 1/2"reach NGK plugs at the next heat range. Longer reach are OK in '34 and '35 engines with ridge running the length of the head.
However, when just turning the engine over on the starter something in cylinders 1 and 8 seems to have hit the plugs in them and has squashed their ground electrodes. The other plugs are OK.
This problem never occurred with the 3/8" plugs.
So I'm guessing the head needs to come off to find out what's going on here - could it be stuck valves or something else ?
Opinions/advice would be very much appreciated, please !
Yes, but so did all the others to varying degrees.
But why is it only happening with 2 plugs and not all 8 ?
They said they are hotter than the Champion J8 and are their recommendation.
I'm using copper wire leads.
Core polarity is correct.
I will drop the carb float by 1/8".
However, my cylinder head should handle 1/2" reach plugs and it's worrying that when I use them, plugs 1 and 8 get squashed electrodes.
Something must be wrong in those cylinders, so I guess I should still remove the head for an inspection ?
I have a spare head gasket, so it's not going to be an expensive exercise.
I am going to have to take the head off in any event because the plug hole for #7 has been helicoiled and the darned thing has come loose and I'll need a new one put in.
On the bright side (I suppose), I'll find out what's damaging those plugs in cylinders 1 and 8.
I will take it off and get it examined by the engineer who'll do the helicoil.
Fingers crossed it'll be OK.
The water pump adapter system has been used for many years, this is a modern example on a 35 engine.
I hope it doesn't come to that but if it does, I'll be back to you for more info.
