Looking for advice on a near totaled '49 Super Six
Hi all, new guy here. I have '49 Super Six that was sadly crushed by a tree in our property that fell on it. Amazingly the car can still start and run. There does seem to be a problem now of something causing a drain on the battery, though the drain goes away if I start it and get the RPMs up a bit. Only the drain comes back if I disconnect and re-connect the battery, so I'm really not sure what's going on there. I'm kind of torn between just selling it as it is or maybe trying to find a similar-ish body in decent shape to put the engine and drive train in. I'm not even really sure what the value would be with what's left of the body and the working engine. Any help or advice is appreciated.
Richard
https://forum.hetclub.org/discussion/366080/1950-commodore-6-fs-by-studebaker-museum#latest
Part out the rest.
Also, what is the body style?
And, what was the extent of the damage? Was just the roof crushed or is the entire body damaged from top to bottom?
Where are you located?
If the car had been in very good condition prior to the disaster, it will have value as a parts car because there will be a lot to salvage (including parts of the body that were not damaged). If the damage had been confined to the roof, there is a chance that some enterprising person could splice on another roof and put the car back on the road. (Especially if the body style is somewhat rare, like a coupe.)
My advice would be to sell the car to some Hudson enthusiast who could then part it out (or fix it), and then just walk away from it. Otherwise, you are spending months or years trying to find just the right car in which to transplant your donor engine. Could happen in two weeks...or 5 years. Just cut your losses, get what you can for the car, and then shop around for a replacement Hudson!
