Ring Gear
Steven
Hi All. I need a ring gear for my 33 T8. I believe 107 teeth.
Thank You
Thank You
what is your ratio?
I hope following helps you find the ring gear
From Hollander Book
#159 /for 32 & 33 terra. 6 & 8, Hollander book, lists two ratios/ 37-9 and41-9.
( with note to a watch 33 pinion )
#229 /Hollanders also lists same ratios 37-9 & 41-9.
for Essex 34 -36 Terra.
for Hudson34-36 6 & 8
( note; Mfg's number for 37-9 ring gear same as interchange #159
I think he means starter ring gear. Parts list says same ring gear for all '33-'35 Terraplanes.0
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 68 Hudson 8
