1928 -29 engine colours
Firstly what is the correct color for the engine on a 1928 Hudson? Secondly was it the same for 1929 Hudson engines? Was the head a different color to the block or the same?
  • 54coupe54coupe Posts: 1,048Member
    In 29, the head and block were a fairly dark green. The crankcase and rocker cover were natural aluminum.
  • 2838Hudson2838Hudson Posts: 10Member
    OK thanks, that is the color my 28 engine is currently, just wanted to confirm it was correct.
  • joejoe Posts: 13Member
    I was looking for the same info...thanks. I am building a 1930 super six.  Essex four door sedan. all the pics I have found are fairly dark green
  • hotsparkhotspark Posts: 2Member
    I wonder where you could by this correct green.I have a 28 super six that I would like to detail.
  • GeoffGeoff Posts: 4,623Senior Contributor
    Probably Model A Ford suppliers would have it.
  • cricketcricket Posts: 13Member
    Bill Hirsch has the correct color
