How fast is too fast?
Hi guys,
I am getting to the last stages of restoring my '26 Essex and I'm wondering what sort of speed the engine will handle.
If I can cruise at 45MPH I'll be happy but from what I can work out the engine will need to be sitting on about 2500RPM I've been told that if the engine is revved too high it doesn't lubricate the big ends properly and then melts them. I do not know if there is any truth to the matter but I wouldnt like to test it either.
So what speeds do you guys cruise at when your out and about in your Essex's?
Cheers, Tristan.
Cheers, Tristan.
Alistair Howard,
http://het.org.nz/
1928 Essex Coach
1929 Essex Coupe
1950 Hudson Pacemaker
Ernie have you ever pushed either of your cars up to 45 for any length of time?
Re the oil - David and I differ in our view here. I have run Penrite HPR30 oil (20W-60) for many years without issue which was recommended to me for the old engines. Maybe if I pushed it harder / faster I would have problems? Who knows, but I do not intend to try and find out.
Alistair Howard,
http://het.org.nz/
1928 Essex Coach
1929 Essex Coupe
Thats interesting what you say in regards to the oil I've currently got HPR 10 in the Essex maybe I will stick with it.
Cheers, Tristan.
regards, Tom
I go by what Geoff says.
I had to surrender my spare block to the man who gave it to me after he had tried to find out how fast his Railton would go and put a rod through his block at about 85 mph.
