52 hudson
52hudsonman52hudsonman Posts: 41Member
what is the differential gear ratio on a 52 wasp with a automatic
  • Uncle JoshUncle Josh Posts: 2,613Senior Contributor
    Should be 3.58.  Jack up one rear wheel.  Rotate 2 turns and count the driveshaft revs.
  • 54coupe54coupe Posts: 471Member
    If it is original to the car, it could be 3.08 or the one in the 3.5- area.
  • 7XPacemaker7XPacemaker Posts: 411Senior Contributor
    3:08 or 3:58 If I am not mistaken.
  • lostmindlostmind Posts: 1,287Expert Adviser
    I think a 3:31 was an option in Wasp?
  • Hudnut54Hudnut54 Posts: 3Member
    If your 52 is built after April of 52 it will have a Dana rear end and 3:07 was the only ratio available for hydromatic
