Engine Mount Springs and Rubber seats.
Attachments :
    All,
    I getting prepared to install the engine, I know, I know, about time!
    I remember reading an post I think from Geoff regarding the springs for the front mounts and the bolt/nut left loose with
    carter installed. I cant seem to locate that wisdom, please refresh my memory.
    Also are you guys replacing the two springs and if so what are their recommended specs.
    I've attached a pic of the motor mount rubber someone posted back when. Where does that wide one with the 6 holes go?
    Thanks Guys
    Jack
