29 Rod End shims
I wanted to ask what the minimum shim thickness is on the rod ends. there are 3 steel shims that are on both sides of all 6 rod ends.Then the brass. Are the 3 steel the minimum or can they also be removed?
It looks like you're new here. If you want to get involved, click one of these buttons!
