Re: Pic from Hudson Parts Book [2 Attachments]
Attachments :
    Hi Geoff,
    Made a new shim this morning. Had to flatten the stock shim width I have a bit as it was a bit too thick. This one went in much easier and stayed in place when wheel was rotated. All vertical play is gone. Outstanding!
    Thanks so much for the easy fix!
    Jack
    -----Original Message-----
    From: 'Geoff Clark' geoffclark@xtra.co.nz [HudsonSuperSix16-29] <HudsonSuperSix16-29@yahoogroups.com>
    To: HudsonSuperSix16-29 <HudsonSuperSix16-29@yahoogroups.com>
    Sent: Thu, Aug 24, 2017 2:15 pm
    Subject: Re: [HSS] Pic from Hudson Parts Book [2 Attachments]
    [Attachment(s) from Geoff Clark included below]
    That is correct.
    New Outlook Express and Windows Live Mail replacement - get it here:
    ----- Original Message -----
    From: Jack Mcmullen forjack842@aol.com [HudsonSuperSix16-29] <HudsonSuperSix16-29@yahoogroups.com>
    Sent: 24/08/2017 5:58:49 PM
    Hi Geoff,
    Here's a pic of the pass side (only pic of this issue I have on disk)...the arrow points to the shim I'm where I'm adding another shim correct? Are we talking about the same place?
    Sent: Wed, Aug 23, 2017 10:41 pm
    Subject: Re: [HSS] Pic from Hudson Parts Book [1 Attachment]
    You won't find it in the '26 manual.  Earlier models were Elliot design, '27 thru '32 Hudson were Revers Elliot.   You need a shim with a .801 hole in the middle.   C
    ut the "C" so that it clips around the pin.
    Sent: 24/08/2017 1:48:10 PM
    Hi Geoff,
    Yes shims sound easier. I'll get down and find the shim. Been looking at the 26 shop manual and see where it is in the picture mow to find it.
    Thanks so much!
    Jack
    Sent: Wed, Aug 23, 2017 6:37 pm
    It is probably the thrust bearing worn.  These are obtainable fro
    m Model A Ford suppliers, but it is a major task to replace, best just to use shims as I mentioned in previous post.
    Geoff
    Sent: 24/08/2017 1:18:45 PM
    Looks like the lower pivot pin bushing. But why today out of the blue?
    Sent: Wed, Aug 23, 2017 3:49 pm
    Subject: [HSS] Pic from Hudson Parts Book
    Sent: Wed, Aug 23, 2017 3:27 pm
    Subject: [HSS] Please Need Advice on Front Drivers Side Axle
    Guys,
    I was swapping out an old tube on the drivers side front. When doing the first pass of tightening I felt the wheel kind of jerk up a bit. Looking closer with hub off there's very noticeable vertical play. This just happened as I mounted the newly restored wheel a week ago and this vertical play was not there. Checked the pass side its solid in the vertical. Removing the spindle cup at the bottom I can see movement of the spindle. Appears that the axle play is rooted there. The upper spindle is solid. Is there an adjustment to remove this play?
    Thanks
    Jack
    #ygrps-yiv-814070702 #ygrps-yiv-814070702AOLMsgPart_2.ygrps-yiv-8140707021_d4b9c467-2298-4cbc-933a-0dfc47945e5d td{color:black;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mkp hr {border:1px solid #d8d8d8;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mkp #ygrps-yiv-814070702aolmail_hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mkp #ygrps-yiv-814070702aolmail_ads {margin-bottom:10px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mkp .ygrps-yiv-814070702aolmail_ad {padding:0 0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mkp .ygrps-yiv-814070702aolmail_ad p {margin:0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mkp .ygrps-yiv-814070702aolmail_ad a {color:#0000ff;text-decoration:none;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-sponsor #ygrps-yiv-814070702aolmail_ygrp-lc {font-family:Arial;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-sponsor #ygrps-yiv-814070702aolmail_ygrp-lc #ygrps-yiv-814070702aolmail_hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-sponsor #ygrps-yiv-814070702aolmail_ygrp-lc .ygrps-yiv-814070702aolmail_ad {margin-bottom:10px;padding:0 0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_actions {font-family:Verdana;font-size:11px;padding:10px 0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_activity span {font-weight:700;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_activity span:first-child {text-transform:uppercase;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_activity span a {color:#5085b6;text-decoration:none;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_activity span span {color:#ff7900;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_activity span .ygrps-yiv-814070702aolmail_underline {text-decoration:underline;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_attach div a {text-decoration:none;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_attach img {border:none;padding-right:5px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_attach label {display:block;margin-bottom:5px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_attach label a {text-decoration:none;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody blockquote {margin:0 0 0 4px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_bold {font-family:Arial;font-size:13px;font-weight:700;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_bold a {text-decoration:none;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody dd.ygrps-yiv-814070702aolmail_last p a {font-family:Verdana;font-weight:700;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody dd.ygrps-yiv-814070702aolmail_last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody dd.ygrps-yiv-814070702aolmail_last p span.ygrps-yiv-814070702aolmail_yshortcuts {margin-right:0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_attach-table div div a {text-decoration:none;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_attach-table {width:400px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_file-title a, #ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_file-title a:active, #ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_file-title a:hover, #ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_file-title a:visited {text-decoration:none;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_photo-title a, #ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_photo-title a:active, #ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_photo-title a:hover, #ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div.ygrps-yiv-814070702aolmail_photo-title a:visited {text-decoration:none;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody div#ygrps-yiv-814070702aolmail_ygrp-mlmsg #ygrps-yiv-814070702aolmail_ygrp-msg p a span.ygrps-yiv-814070702aolmail_yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_green {color:#628c2a;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_MsoNormal {margin:0 0 0 0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody o {font-size:0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_photos div {float:left;width:72px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_reco-category {font-size:77%;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_reco-desc {font-size:77%;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody .ygrps-yiv-814070702aolmail_replbq {margin:4px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mlmsg table {font-size:inherit;font:100%;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mlmsg select, #ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody input, #ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody textarea {font:99% Arial, Helvetica, clean, sans-serif;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mlmsg pre, #ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody code {font:115% monospace;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mlmsg * {line-height:1.22em;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-mlmsg #ygrps-yiv-814070702aolmail_logo {padding-bottom:10px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-msg p a {font-family:Verdana;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-msg p#ygrps-yiv-814070702aolmail_attach-count span {color:#1E66AE;font-weight:700;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-reco #ygrps-yiv-814070702aolmail_reco-head {color:#ff7900;font-weight:700;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-reco {margin-bottom:20px;padding:0px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-sponsor #ygrps-yiv-814070702aolmail_ov li a {font-size:130%;text-decoration:none;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-sponsor #ygrps-yiv-814070702aolmail_ov li {font-size:77%;list-style-type:square;padding:6px 0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-sponsor #ygrps-yiv-814070702aolmail_ov ul {margin:0;padding:0 0 0 8px;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-text {font-family:Georgia;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-text p {margin:0 0 1em 0;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-text tt {font-size:120%;}#ygrps-yiv-814070702 .ygrps-yiv-814070702aolReplacedBody #ygrps-yiv-814070702aolmail_ygrp-vital ul li:last-child {border-right:none !important;}
