Re: 29 Front/Read Bearings & Races
My Lord, the Timken cups are over $150 each, these are just the races, the bearings are at least $100.
Time for a substitute! Has anyone found a newer much lower cost substitutes?
Thanks Jack
Timken #412A
-----Original Message-----
To: forjack842 <forjack842@aol.com>
Sent: Mon, Jun 19, 2017 3:52 pm
Subject: Bearings,
#ygrps-yiv-342499827 #ygrps-yiv-342499827AOLMsgPart_1.ygrps-yiv-3424998272_40d68282-3fe5-44d1-add0-f263869ca6f0 td{color:black;} _filtered #ygrps-yiv-342499827 {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #ygrps-yiv-342499827 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-342499827 {font-family:Georgia;panose-1:2 4 5 2 5 4 5 2 3 3;}#ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody p.ygrps-yiv-342499827aolmail_MsoNormal, #ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody li.ygrps-yiv-342499827aolmail_MsoNormal, #ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody div.ygrps-yiv-342499827aolmail_MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}#ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody a:link, #ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody span.ygrps-yiv-342499827aolmail_MsoHyperlink {color:blue;text-decoration:underline;}#ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody a:visited, #ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody span.ygrps-yiv-342499827aolmail_MsoHyperlinkFollowed {color:purple;text-decoration:underline;}#ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody span.ygrps-yiv-342499827aolmail_EmailStyle17 {font-family:"Calibri", "sans-serif";color:windowtext;}#ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody .ygrps-yiv-342499827aolmail_MsoChpDefault {} _filtered #ygrps-yiv-342499827 {margin:1.0in 1.0in 1.0in 1.0in;}#ygrps-yiv-342499827 .ygrps-yiv-342499827aolReplacedBody div.ygrps-yiv-342499827aolmail_WordSection1 {}
Subject: Bearings,
Hello Jack,
Back when I painted my wooden wheels I use a wheel stand from our Horseless Carriage Club.
This stand made many trip through the members to paint the old wooden wheels.
It have a cone that fit over the race front and back to keep the paint out and you could spin the wheel
To get all sides painted on the spokes..
The paint shop should of covered this part of the hub to keep paint out of the race..
Any way here are the numbers I used to replace my wheels bearings..
I have a parts book for my car and the numbers they list are still good today.
Here are the numbers for these bearings..
Inner bearing cone Timken #415
Inner bearing cup Timken #412A
Outer bearing cone Timken #315
Outer bearing cup Timken #312
You will find these large bearing are on the expensive side.
I did replace mine and I think the inter bearing was around $50.00..
The cup is not so expensive.. I hope this helps you.
Bob
