Re: [HSS] 1919 Model O Engine trouble
hudson@unette.co.uk wrote:
passage between the centre cylinders from the carburettor.
If they don't I can get them here for you @ $70 each.
distributor, driven off the same shaft by a skew gear.
can photocopy for you.
of the water will circulate through them instead of the other smaller
holes around the block, leading to localised overheating. They were
for casting puroposes, and the parts books list special washers for
putting in these.
needed.
Geoff Clark. (N.Z.)
>****Where exactly is this crack? I understand the '19 models have a
> I have a crack in the inlet tract on the block of my 1919 model 0 has
> anyone any experience of repairing this block?
>**** Olson's Gaskets, ( Olsongasket@fincom.com) should have them.
> Can I get gaskets readily for this engine?
>**Doesn't sound right. Oil pump is below and in front of the
> I have anoil pump, belt driven from behind the water pump, is this
> correct? It appears to feed what visually looks like the plunger pump
> as fitted to my 1913 Huson model 37 (Continental engine) but this is
> sited below the distributer housing.
>I have the book "What you should know about your Super Six." 60 pages,
> Is there available literature for this model.
>**These holes should be blocked off in all Super Sixes, otherwise most
> Lastly on the head / block there are two large water holes which had
> been obscured by some illfitting copper plates, my car lived in
> Canada could this have beena climatic fix or is there a right or
> wrong to their presence?
putting in these.
>Not specifically, but do keep in touch with other members for help if
> Any other useful tips whilst rebuiding?
needed.
Geoff Clark. (N.Z.)
> LOW, LOW new car prices. Click here !!
> http://click.egroups.com/1/5463/5/_/695705/_/961953591/
> Community email addresses:
> Shortcut URL to this page:
