Re: [HSS] Marvel Carburetor Jets
Tom Goodman wrote:
never bothered measuring the actual size of the hole, but the larger
number is a bigger hole. I have reduced the main sizes as mentioned
before. If anyone had a set of numbered drills then the actual
diameter could be ascertained by inserting the right number drill in the
jet and measuring the dirlll with a micrometer or dial gauge, but I go
by the "hit and miss" method, and it works fine. Remember that it is a
combination of float level, flapper spring tension, and jet size that we
have to consider, and all three have to be spot-on to get your Marvel
working correctly, taking into account also the height above sea level.
Have fun!
Geoff.
>Regarding sozes, yes, the middle figure designates size, but I have
> Background: Standard Jets for Marvel "VB" Carburetors are specified
> in the book that Pete so generously shared as follows:
> High Speed Jet P/N 49-140-D-28
> or 49-160-D-28
> Intermediate HS Jet P/N 49-220-E-24
> or 49-180-E-24
> (the reason for the "or" is that Marvel made a change mid-run to get
> better performance, I suppose)
> Now: According to the Marvel book (P 13), jets should be changed for
> high altitude operation. We already knew that and Geoff suggested a
> real good way to do that with wire hanging into the opening of the
> jet.
> Marvel's suggestion for High Altitude operation is to use the
> following jets:
> High Speed Jet P/N 49-130-D-28
> Intermediate HS Jet 49-170-E-24
> Question: Does the second number in the part number indicate the jet
> size? For instance, in a 49-130-D-28, is the jet size .013"? That
> sure would stand to reason as far as I am concerned. If so, this
> gives me some indication of (1) what I have and (2) what I need to do.
> Thanks for enduring all of this and for your responses.
> Tom
> The Ultimate in Performance, RaceSearch.com, proudly presents, The Ultimate
> Motorsports Collectible Auction featuring memorabilia, parts and racecars.
> http://click.egroups.com/1/5268/5/_/695705/_/961794839/
> Community email addresses:
> Shortcut URL to this page:
Have fun!
Geoff.
