29 H tech. "stuff"
For John, Tom, et al:
From the A.E.A (Auto. Elec. Assoc.)"Standards of Adjustment Issued
Jan. '35" for the '29:
Spark plugs: size 18 m.m., orig. equip. AC G-10, gap .025
Distributor: A-L IGA-4058; pt. gap .018 to .020 (after 1000 mi. use)
.020 to .024 (newly installed)
condenser: A-L IG-1298; capacity .20 to .25 mfd.
manual advance: 14 degrees (dist.); auto. adv.- semi auto. 18
degrees at 1600 rpm (max. adv. to dist. degrees at dist. rpm)
Coil: A-L IG-4065
Ignition timing: "Use Timing Lamp - Breaker contacts to open for No.
1 Cylinder when punch mark on flywheel (3 teeth before "DC 1 & 6
mark") is opposite timing pointer. Manual spark control fully
advanced."
Starting Motor: A-L MUA-4001
Generator: A-L GAB-4008
Max. output safe setting: hot - 12.5 amps. 8.0 volts at 1550 rpm
of generator
cold - 14 to 16 amps 8.0 volts at 1300
rpm of generator
"(These readings taken at generator. Readings at ammeter on
dash will be approximately 2 amperes lower")
Cut-out relay: A-L CB-4014 (closes at 7 to 9 volts at545 to 625
rpm; opens at .5 to 2.5 amp. discharge).
Brush spring tension - 16 to 24 oz. (all brushes).
Valves: hot, int. .004, exh. .006
timing: "Inlet valves open 7 degrees or 2 1/2 flywheel teeth,
or .019" piston travel after top dead center"
Carburetion: Marvel VB (No. 10-724)
Idle adj. - air screw Idle at 5 to 7 mph; turn clockwise to richen
Fixed Jets: high speed Part # 49-160-C-28
low " " " 47-160-A
intermediate H.S. - # 49-180-E-24
metering pin - 84-090-C
float level is 19/64" "Measure from top of float chamber to top
of float with float held in closed or top position".
Hope this will "cover all the bases",
Coil: A-L IG-4065
advanced."
of generator
rpm of generator
low " " " 47-160-A
