Overdrive Question
State of Affairs:
'28 Hudson with Stewart Warner overdrive, apparently added after
manufacture. Car is presently running on 12Volts. No idea if O.D.
solenoid has been converted.
Controls are:
(a) T-handle (marked Overdrive) Plunger with "in" and "out" position
(assumed that "out" means O.D. disabled) and (b) A switch that is
supposed to control engagement of O.D.
The problem: Freewheeling seems to be active all the time (meaning
the car freewheels going downhill...not exactly what I want it to do)
and I cannot exactly determine if O.D. is engaged. All this is
regardless of the position of the Plunger (a) and the Switch (b). I
feel that the acceleration in 3rd gear is a bit sluggish and suspect
that O.D. is active regardless of the position of the controls.
Diagnosis or Diagnoses or even suggestions for the next step???
Thanks a bunch. By the way, I just received a June 1928 edition of
"Hudson Super-Six Parts List" with cutaway views and parts names and
Hudson Part Numbers (for whatever it is worth)and I will be happy to
share this if anyone wants/needs it. By the way, since my Overdrive
was aftermarket, it is not shown.
Tom Goodman
Controls are:
Tom Goodman
