Re: [HSS] Re: <no subject>
Tom is properly concerned about his brakes coming down Pike's Peak. Well,
Tom, don't forget your gears! Just because your Super Six will climb the hill
in top or second doesn't mean that you need to come down in the same gear. In
first gear you would be unlikely to use your brakes at all. Second allows
more speed but still allows a fair amount of compression breaking. You may
annoy a few people by driving so slowly, but . . .
Due to the low compression ratios used in the 20s, the motor will not
hold you as well as a modern engine of the same displacement would.
Nonetheless, gearing down should be all you really need. Is there a spot to
pull over and allow your brakes to cool on the trip down? Perhaps it would be
worth while to plans on a few breaks on the way down.
Paul O'Neil, Hudson29@aol.com
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.onelist.com/subscribe/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
Fullerton, California USA
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
