John -
The displacement is 288 cubic inches.
The chassis # is on a plate on the firewall unless it has been
removed. The same # should be on the top right rear frame horn by
where your gas tank filler is located (at least it is on a '29); it
is stamped into the metal.
Post the # & can tell you if definitely a '28.
