Re: [HSS] A few questions...
John Lawton wrote:
front and 38 in the rear. Steering will never be "light", but
attention to geometry will optimise things. Caster should be 0 to 1
deg positive (adjusted by wedges under the spring). Only use heavy oil
in the steering and joints, not grease.
worn excessively, cut gap down to .015" for better orperation. Set
timing by timing light preferably, but to check static, align pointer
in hole at left rear of crankcase against the t.d.c. mark on flywheel,
and points should be just opening. (Have advance/retard lever fully
advanced for this, and hold slack in shaft anticlockwise) This is only
for initial setting, as you will probably need to advance for optimum
performance, and with the timing light will be about 3 flywheel
advanced.
clearance between drum and shoes. Front wheels, just remove the
bearing nut, and the wheel comes off. Rear wheels, you will have to
make a puller our a billet of steel, machined to screw on to the hub cap
thread, and a large bolt threaded into the centre. Screw the puller on
to hub, and screw the bolt hard up against the axle end to remove.
Alternative method is to jack car up on side opposite the axle you want
to remove, loosen nut, hold brass drift against axle end, and belt the
hell out of it with a ten pound sledge hammer. One good blow should do
it. Weight of car provides inertia to jolt hub off taper.
>***The original size tyres are 6.00x19", and pressures are 35 in the
> Hi everyone,
> It has fallen to me to get my wife's 1928 SuperSix on the road, and I too
> have felt unfamiliar with the 20's technology, coupled with the fact that I
> have no technical info on the car! This makes my progress painfully slow.
> I've a couple of questions:
> What size tyres should be fitted on which axles, and what tyre pressures?
> Presently I have 6.00 x 19 on the rear, and 6.5 x 19 on the front. The
> steering is fiendishly heavy with 35psi in the tyres.
>*** .020", but check for wear in bushings, (push shaft sideways). If
> What should the contact breaker gap be? And how do I set the timing?
advanced.
> How do I inspect the brake shoes and how do I remove the wheels?*** There are inspection plates on the drums. check for minimal
>Geoff Clark, Tech. Advisor, N.Z. H.E.T. Club.
> I will put up some photos of the car on a website very soon!
> Best wishes,
> John Lawton
>** Hope this is of some help.
> Hot off the press- summer's here!
> School's out and it's sizzling hot. Whether you're planning a
> graduation party, a summer brunch, or simple birthday party,
> shop GreatEntertaining.com before your next celebration.
> http://click.egroups.com/1/4473/4/_/695705/_/959792229/
> Community email addresses:
> Shortcut URL to this page:
