Vacuum tanks.
I note the comments re fitting electric fuel pumps to replace the vacuum
tanks. This is like hiring a bulldozer to crush a butterfly, as the
vacuum tank is the most reliable unit you can ever have. In 45 years
motoring, (400,000 miles) in my '28 Essex, and almost 30 years in my '29
H 7 pass, the vacuum tanks have only played up once on each car. In
the Essex, the float developed a leak, the tank filled right up, and
sucked fuel through the vacuum line. Easily fixed, and this 30 years
ago. In the Hudson the flapper valve assembly unscrewed and dropped
into the bottom of the tank. Up to '27 the tanks had cast pot-metal tops
with a toggle lever which flipped the valve by a brass spring as the
float rose. The pivot points can wear, sometimes delaying the action,
but the most common problem with these tanks is the brass valve seat
popping out of the top. If this happens, re-insert, and carefully pin
punch around it to hold it in. '29 thru '31 models had leverless
tanks, and there were three variations of this. The first in '28 used
a goosenecked float wire to actuate the valves, and the wires from the
valves had little circles in them. The second had a slot in a flat
strip on the float, and the valve wires had right angles in them, and
there is vary small compression which must go underneath the valve
wires. I'm not familiar with the constant suction type, but in '30
there was a "vacuum booster" used. This is a small venturi venting to
the atmosphere directly behind the vacuum line, and the wiper connection
goes out the top. The idea of this is that there is a constant stream
of air going past the top of the tank, and this produces the difference
in pressure to induce vacuum in the tank, rather than engine vacuum
alone. This eliminates the rolling due to enrichment of mixture as the
top chamber fills, as on earlier models. In all models, the most
important thing is to have a good top gasket, and thin rubberised cork
is the best for this. Also, some models have pot-metal flapper
valves, and these tend to swell and crack. I usually turn the fibre
flap around to give a new surface, and carefully sand off the face of
the pot-metal body to give a flat surface. '29 thru '31 models had the
filter bowl on the bottom, and these are supposed to shut off the fuel
flow when you undo it, but this seldom happens, as the cork seat gets
distorted, so have a container handy to catch the fuel if you undo
this.
Geoff Clark.
this.
Geoff Clark.
