Re: [HSS] The Vacuum Tank
To Tom Goodman. Found my books on the vacuum tank. Will copy and send
to you tomorrow (Wed.). Pete W.
>From: "Tom Goodman" <tgood70779@aol.com>
>To: HudsonSuperSix16-29@egroups.com
>Subject: [HSS] The Vacuum Tank
>Date: Mon, May 15, 2000, 7:59 PM
> To: Pete Welzbacker and others:
> Thanks for your responses. I have not yet received my WTN but I only
> joined a couple of weeks ago. Anyhow, the e mail address in HET club
> members' e mail list (online version) does not work for you, Pete.
> The first letter in the truncated e mail address that comes up in
> here was different from the old one for you so I can surmise that you
> have changed ISPs. Anyhow, I will post my address below and will
> greatly appreciate any information you can copy and send me.
> I am sure that the float is OK, the flipper and springs seem OK, I
> think the thing is vacuum tight but I do have suspicion about either
> the valving (2 of them) controlled by the flipper and the almost
> necessary check valve that MUST exist between the top compartment of
> the tank and the bottom part to prevent sucking the feed line from
> tank to carburetor dry. My guess is that the check valve is not
> working (assuming there is a check valve) OR that the vent valve
> operated by the flipper is not working correctly. The vacuum valve
> operated by the flipper seems to be OK but I have not 100% figured
> out the purpose of the other valve that seems to vent the top chamber
> either to the atmosphere or to the lower/outer tank. A blowup would
> be useful.
> My address at work is:
> Tom Goodman
> c/o ILSI
> 4750 Edison Avenue
> Colorado Springs, CO 80915
> my e mail is tgood70779 @ A O L. com (leave out the extra spaces)
> Thanks for your response and advice...Also thanks to the others of
> you who responded. If I could ever lay my hands on some service
> information (planning a trip to the Bermuda Triangle soon), I might
> not have to ask such stupid questions.
> Tom Goodman
> Accurate impartial advice on everything from laptops to table saws.
> http://click.egroups.com/1/3020/4/_/695705/_/958445981/
> Community email addresses:
> Shortcut URL to this page:
