vacuum tanks
Tom:
re the vacuum tank and venting. there is a vent hole on the edge of the
lid that
must align with the main housing (the reason for the roll pin on the edge)
so that the lower
chamber can drain into the carb while the upper chamber is refilling from
the fuel tank,
There is a flappper valve in the bottom of the upper tank (the tank that
lifts out) when vacuum
is applied to the upper tank this valve is sucked closed, allowing the upper
tank to draw a vacuum and therefor fuel from the tank, when the upper tank
fills,the float lifts, the springs go over center, and the valve on the
vacuum line trips, closing off the line from the engine (you can hear the
change in engine rpm when this happens). The upper tank then is allowed to
vent to atmosphere and the weight of the gas in the upper tank opens the
flapper valve and the lower chamber refills. Took me years to figgure
this out...If all is working well, you can here the change in engine rpm as
the vacuum tank draws fuel from the tank and then stops drawing , then
starts again. Bill
lid that
so that the lower
the fuel tank,
starts again. Bill
