vacuum tank "pumping"
Tom - a vac. tank doesn't pump, it simply pulls up gas from the gas
tank by vacuum. Has someone put an elec. fuel pump in your gas line?
If so, that can cause flooding.
The vac. tank supplies the carb. strictly by gravity feed - if you
have an elec. fuel pump in the system, it should be clear back by the
gas tank & will req. a pressure regulator valve as vac. tank gaskets
won't be able to hold the pressure = flooding & leaking.
I have at least 1 spare '29 Hudson Calif. "pink slip"; perhaps
someone like John Soneff in Denver might have a spare Colo.
equivalent he would give or sell you for your '28.
Be devious - how would Colo. DMV know you brought the car from Canada
unless you tell them? Tell them you lost the paperwork, or inherited
it from your uncle & he lost it, or whatever, LOL. Pete
