Generator 6 Volts vs 12 Volts, etc.
Thanks for the abundance of response that I got from my inquiry about
rewinding my generator. Perhaps I did not make myself clear enough:
I "think" that my generator does not generate now. "How?", you might
ask, "do you know that?"...Let me tell you what I did:
First I recently bought the car and it had been converted to 12 volt
operation before I bought it. I would assume the starter is running
without modification and I know the lights have been changed over.
Any dashboard instruments that require a voltage supply seem to have
been connected through a voltage-dropping circuit and that seems to
work, too. The battery is 12 volts and everything is hunky dorey but
the generator does not seem to charge the battery.
I checked the voltage on the "inside" of the cut-out relay and found
zilch...nada....zero even when the engine was turning over at fairly
high RPM (for that engine, "high" = around 2,000). Without removing
the generator, this leads me to believe that the generator is
not "ginning". Now, armed with that knowledge, I decided to see if I
could get the generator rewound to be able to charge the battery and
posted.
I suppose I could replace the battery and probably the brushes in the
generator but that would require some re-doing of lamps, etc. so, it
seems to me that I might as well throw some money at the problem and
get the generator modified to output somewhere around 13 or 14 volts
to charge my battery.
Sorry for the verbosity but I just wanted to make everything
completely clear and I DO thank everyone for their tips and ideas. I
do not have much experience working on Hudsons but I kind of
understand electricity, being a lifelong Electic one.
Anyhow, I still would like to see if it is possible to get someone
who knows about these things to rewind the sucker and to score a
couple of those crank hole covers.....already nickel plated, of
course.
Thanks again folks.
Tom Goodman
tgood70779@aol.com
posted.
course.
Thanks again folks.
Tom Goodman
tgood70779@aol.com
