How to fit front axle bump stops on 34/35 cars
Old Fogey UK
Nothing in the mechanical procedure manual about this.
Please could somebody tell me how to do it ?
Front bump stops are held in place by the U bolts. Jack the car under the axle, remove the U bolts - tackling some of the nuts can be a challenge - put bump stop in place. I'd suggest undoing and re-doing one side at a time.0
Thank you very much, Bob.0
Wire brush exposed thread, lubricate and use a torque gun and socket. Do one nut at a time. May need long reach sockets for the last nut.0
I won't upset the location of the axle by removing the u-bolts, will I ?0
These are the bump stops the ROC sent me.
Do they look right ?
I cant see what holds them under the u-bolts.
You only have part of the story there. The originals were held in place by a sheet metal pressing that went over the square base and extended out under the U-bolts. You can sort of make out the pressing in the photo of a dead front bump stop. If you Sikaflex those rubbers to a piece of heavy gauge sheet metal you will be able to get them mounted.
So long as you lift and support the car by the front axle you won't disturb its location to the spring when you undo the U-bolts.
As a reasonably competent lawyer but an inadequately skilled mechanic, on reflection I think I'll leave this job to the 83 year old founder of my local restoration workshop who sorted out my steering a couple of weeks ago.
He hasn't worked on prewar American cars since the 1950s, so he says doing my car is a trip down memory lane for him !0 -
What is the “ROC” mentioned above as a source for these stops?regards, Tom0
Railton Owners Club0
The Railton Owners Club operates a very good parts scheme for its members.0
I always run a die from a tap-die set up and down the threads to clean them before trying to loosen the nuts. This way you don’t crank the nuts down over the built up rust and crud. Lots of penetrating oil, and heat may be needed.0
I'd like to find one of these butees because there's one missing on my survivor
JACK356 said:I'd like to find one of these butees because there's one missing on my survivor0
OK0
ROC no longer stocks these items.
regards, Tom0 -
Try wildrick rubber?0
I think that there are a number of modern substitutes of similar size and shape that will do the job.
You just need a helpful parts store to help identify them.0 -
What version of Cortina?0
I think it was Mk1 or Mk2 but can't remember which, sorry.0
bob ward said:What version of Cortina?0
Dimensions of bump stop in inches -
Base 1.56 x 1.93 x 0.45
Cylindrical buffer 1.43 high, 1.38 diameter
