Oil
raycox
What brand and grade of oil is reccomoned in 1924 6 cylinder Essex also distributor points gap thanks Ray cox
Don't know if this helps but I have a 1939 six cylinder and I use Shell 15W40. Its a 212 CID splasher six The old engines need zinc and that has it. Not sure and points and gap for yours but a search on the web may yield results. Also if you haven't already done so please consider joining the HET Club. You will find lots of info and people willing to help and give sound advice. Alex Burr has a web site devoted to hudson manuals also and that may help you.0
Points gap is best at .017. You don't need a high-zinc oil in your Essex, a good quality 10W-40 is fine.0
Thanks for your info0
I recall zink was to reduce wear on lifters and cam lobes.
An Essex has roller lifters, much less pressure.0 -
Zddp wasn’t even developed until the 1940’s.. more than a decade after this engine design was introduced into service.0
Millers oil avec zddp https://www.millersoils.fr/boutique/millers-classic-millerol-m30-huile-sans-detergents/0
I always used Morris's Golden Film single grade oil (Britain's home-grown equivalent of Penrite and very well regarded over here) but it isn't cheap.
So, as I have to chuck it away every 12 months, I have gone over to using an un-hyped plain SAE 30 for classic cars from my local parts store - 2/3 the price and, in all likelihood, no worse for my engine.
David, I would recommend that you change to a Zinc additive oil. The lifters and cams are very susceptible to wear in these motors.0
At the next oil change, Geoff.0
