Voltage regulator
hudsonsplasher1hudsonsplasher1 Posts: 762Senior Contributor
This may have been discussed before but is it normal for the voltage regulator to vibrate at low rpm's? Generator checks out ok, and the vibration goes away (or just can't hear it) at higher rpm's. A electrical engineer friend said they are designed this way, though my other Hudson's don't do this.  Anything to worry about, or should I just leave it alone? Any help much appreciated.
Gene.
  • hudsonsplasher1hudsonsplasher1 Posts: 762Senior Contributor
    A side note, maybe it's not the correct regulator for the car. Anyone know what is the correct one for a 49 Commodore 8 is?
  • LanceLance Posts: 882Member
    The correct voltage regulator for your 1949 Commodore is an AutoLite VRR  4001A   with 4 terminals.
    Thanks Lance, that's what I have.
  • 7XPacemaker7XPacemaker Posts: 402Senior Contributor
    I think that I have a NOS one if yours is toasted.
    Thanks for the offer, what are you asking for it?
