1932/33 hudson super 5 window coupe windshield frame and pass door latch assy.
needed 32/33 hudson super coupe windshield frame, pass door latch assy.  driver door window regulator.
  • 32hudsonhotrod32hudsonhotrod Posts: 3Member
    wanted 1932/33 coupe interior parts, window garnish mouldings
  • Jon BJon B Posts: 7,085Administrator
    edited May 21
    Photos and dimensions might help (and you could also e-mail them to Hudson vendors who advertise in the WTN).  Some people might have accumulations of unknown Hudson parts, and not know which years they fit unless they had a photo of them.
    Also, this is definitely a Hudson, not a Terraplane?
  • 5433HET5433HET Posts: 81Expert Adviser
    edited May 21
    https://windshieldframes.com/
    This place can fab them...if yours is a '32, did you remove the visor?  Either way, you'll need to give them perimeter measuremenrs.
    thanks for your help
  • tedted Posts: 28Member
    I have some 4 dr  33 terraplane  parts doors.  Possible  window winders will work on2 door.. I will have  latch mechanisms for 4 dr aswwel. Try to find out if interchangeable.   Do u have  some of your drivers winder.glass in a 4dr is much shorter.  Latch parts would be  same. Cleansweep@xplornet.ca
    Post a picture  of your dash gages.  . If your car is 32 or33 Hudson or early 32 essex.  It will b a different  body than a terraplane.   Post pictures  of front fenders .   ur car might b a 3 terraplane  with novisor
    1933.
