1930 Essex
54coupe54coupe Posts: 331Member
I'm trying to help soon the other side of the world... Would someone with a 1930 Essex coupe be able to take some measurements of the outside rear window area for me? Are any other years the same?
  • 54coupe54coupe Posts: 331Member
    Back to the top... any help?
  • ESSX28-1ESSX28-1 Posts: 1,381Senior Contributor
    Try Barry Davis in NZ.  HETbarrysusan1930@gmail.com (drop the HET) He has both a '30 Essex Challenger Sedan & a '30 Essex Country Sedan
    Thank you ESSX28-1. Do you know anyone with a coupe?
  • HansHans Posts: 75Senior Contributor
    file:///C:/Users/hajac/AppData/Local/Packages/Microsoft.MicrosoftEdge_8wekyb3d8bbwe/TempState/Downloads/1930_hudson-essex_reference_sheets%20(1).pdf
    Why not use the references in Alex's data in this club.
    Glass sixes for 30 Essex is here.
    What I'm looking for I a measurement of the window opening, and the distance from the top of the beltline to the bottom of the window opening, for a COUPE. this is for a person who is trying to recreate the missing rear window area on the back of his car.
  • MikeSheridanMikeSheridan Posts: 107Member
    I see a number of 1930 Essex Coupe owners listed in the roster. You could contact them directly and ask for help.
    You could try Graham Sussey. He had a 30 Essex Coupe & may still have it.
    Graham Saussey, at HETcview@xtra.co.nz
