1932 Hudson
1954Hudson
Looking for 2 cowl vent seals
About 4 1/2 x 80
Does it use an O ring type seal like a 29? Or a flat one like 36 and newer? If it's a flat one, You may check with Wildrick for dimensions, and cut one down. I did that for my Jet... Used one for a 36-47, and cut a section out of the part that went across the front of the vent... The rear side was the right length. If it is an O ring type, you can buy any size you want from McMaster-carr.0
its a flat one Thanks Ron0
Back in the day Fullline listed them as HR-21
